I have code here that gives errors when compiling it for the RedBoard but not for the Uno.
The errors I get are associated with TCCR0B, TCCR1B, and TCCR2B.
The code is from Infineon website for Low Side Switch Shield with BTF3050TE for Arduino, it is a Arduino development board using automotive Infineon MOSFET for applications.
// Pin definition
#define LED_0 4
#define LED_1 A4
#define LED_2 2
#define LED_3 10
#define ONOFF_1 A1
#define ONOFF_2 A2
#define ONOFF_3 A3
#define PWM_1 6
#define PWM_2 11
#define PWM_3 9
#define S_0 8
#define S_1 5
#define S_2 3
#define S_3 7
#define S_4 A0
#define SRP_1 13
#define SRP_2 12
#define SRP_3 A5
/* Initialization of global variables
Change these parameters to modify frequency and initial duty cycle*/
int input;
int duty_cycle[3] = { 204, 204, 204}; // Variables, containing the desired initial duty cycle value of each PWM in (1/2.55)%
int freq_divisor[3] = { 1, 1, 1 }; // Frequeny of PWMs in 62500Hz/freq[0], 31250Hz/freq[1], 31250Hz/freq[2]
// Available values for freq_divisor[0] and freq_divisor[2] are 1,8,64,256,1024
// Available values for freq_divisor[1] are 1,8,32,64,128,256,1024
int res = 10; // Debounce cycles
bool debounce(int pin) { // debounces digitally the tactile push button
if(digitalRead(pin)) { // INPUT: pin to debounce
for(int32_t i; i<160000;i++) {}
while(digitalRead(pin)) {}
return true;
return false;
void increaseDutyCycle(int number) { // increases the duty cycle by on discrete step equal to 2.55%
duty_cycle[number]+=res; // INPUT: Number of PWM
if(duty_cycle[number] > 255)
duty_cycle[number] = 255;
void decreaseDutyCycle(int number) { // decreases the duty cycle by on discrete step equal to 2.55%
duty_cycle[number]-=res; // INPUT: Number of PWM
if(duty_cycle[number] < 0)
duty_cycle[number] = 0;
void setPwmFrequency (int pin, int divisor) { // sets PWM frequency
byte divisor_byte; // INPUT: Number of PWM, divisor
// refer to l.25-28 or arduino homepage for further information about the divisor
if(pin == 5 || pin == 6 || pin == 9 || pin == 10){
switch(divisor){
case 1:
divisor_byte = 0x01;
break;
case 8:
divisor_byte = 0x02;
break;
case 64:
divisor_byte = 0x03;
break;
case 256:
divisor_byte = 0x04;
break;
case 1024:
divisor_byte = 0x05;
break;
default:
return;
if(pin == 5 || pin == 6){
TCCR0B = TCCR0B & 0b11111000 | divisor_byte;
} else {
TCCR1B = TCCR1B & 0b11111000 | divisor_byte;
} else if(pin == 3 || pin == 11){
switch(divisor){
case 1:
break;
case 8:
break;
case 32:
break;
case 64:
break;
case 128:
break;
case 256:
divisor_byte = 0x06;
break;
case 1024:
divisor_byte = 0x7;
break;
default:
return;
TCCR2B = TCCR2B & 0b11111000 | divisor_byte;
void setup() {
// Pin assignment and setting PWM frequency
pinMode(LED_0, OUTPUT);
pinMode(LED_1, OUTPUT);
pinMode(LED_2, OUTPUT);
pinMode(LED_3, OUTPUT);
pinMode(ONOFF_1, INPUT);
pinMode(ONOFF_2, INPUT);
pinMode(ONOFF_3, INPUT);
pinMode(S_0, INPUT);
pinMode(S_1, INPUT);
pinMode(S_2, INPUT);
pinMode(S_3, INPUT);
pinMode(S_4, INPUT);
pinMode(SRP_1, INPUT);
pinMode(SRP_2, INPUT);
pinMode(SRP_3, INPUT);
setPwmFrequency(PWM_1, freq_divisor[0] );
setPwmFrequency(PWM_2, freq_divisor[1] );
setPwmFrequency(PWM_3, freq_divisor[2] );
void loop() {
if(debounce(S_0)) // Toggles LED0; LED0 indicates whether the duty cycle of one of the PWMs will increase or decrease, when pressing S1, S2 or S3
digitalWrite( LED_0, !digitalRead(LED_0));
digitalWrite(LED_1, digitalRead(SRP_1)); // LED1, LED2 and LED3 will emit light once a fault feedback is present on one corresponsing Low Side Switch
digitalWrite(LED_2, digitalRead(SRP_2));
digitalWrite(LED_3, digitalRead(SRP_3));
if(debounce(S_1)){ // S1, S2 and S3 will change the duty cycle of the corresponding Low Side Switch
if(digitalRead(LED_0)) {
increaseDutyCycle(0);
} else {
decreaseDutyCycle(0);
if(debounce(S_2))
increaseDutyCycle(1);
} else {
decreaseDutyCycle(1);
if(debounce(S_3))
increaseDutyCycle(2);
} else {
decreaseDutyCycle(2);
if(debounce(S_4)) { // S4 resets the Fault Feedback; SRP1, SRP2 and SRP3 will be pulled to ground and thus reset the Faul Feedback, afterwards the pins will be set to input again.
pinMode(SRP_1, OUTPUT); // For further information regarded the Fault Feedback, please refer to the datasheet of the BTF3050TE
pinMode(SRP_2, OUTPUT);
pinMode(SRP_3, OUTPUT);
digitalWrite(SRP_1, LOW);
digitalWrite(SRP_2, LOW);
digitalWrite(SRP_3, LOW);
if(digitalRead(ONOFF_1)) { // The corresponding Low Side Switch will turn on/off depening on the DIP-Switch channels.
analogWrite(PWM_1, duty_cycle[0]);
} else {
analogWrite(PWM_1, 0);
if(digitalRead(ONOFF_2)) {
analogWrite(PWM_2, duty_cycle[1]);
} else {
analogWrite(PWM_2, 0);
if(digitalRead(ONOFF_3)) {
analogWrite(PWM_3, duty_cycle[2]);
} else {
analogWrite(PWM_3, 0);
