May mounting holes be machined in the RV-8803 board in the same location as the SparkFun Real Time Clock Module - RV-1805? If not where may they be machined?
Tony
Tony
That appears fine, as long as the hole/sizing doesn’t hit the battery tabs on the back (you’re basically just wanting to dodge the lines on the front (“traces”), and also dodge the stuff on the back) ![]()
Thank you Russel,
I’ll be placing an order soon.
