Using Arduino IDE 1.8.19 on my Windows 11 (up to date version) running on my HP Envy (intel i7) , I have not been able to properly connect the SparkFun SAMD21 Pro RF in order to upload a sketch. The PORT is ghosted on the Tools submenu. While I suspect it is a driver problem, I have not found any drivers to work.
Window 11 did not auto detect the device.
Reviewed Device Manager, no related device item listed under USB items, Other Devices, no Ports (Com & LPT)
attempted to add legacy hardware Port (COM & LPT)
tried the sparkfun.inf / sparkfun.cat download, selecting the SparkFun SAMD21 Pro device, received error : "error
occurred during installation, hash on this file is not present in the specified catalog file, file likely corrupted."
Have searched forum high and low for suitable drivers and nothing works. I followed the hookup guides (found some of that to be well out of date), gleaned suggestions from other posts and tried them, again to no avail.
I ordered a new SparkFun SAMD21 PRO RF and new USB cable and repeated steps above, with the same results.
For background, 2020 I had my earlier SparkFun SAMD21 PRO RF board working with the same sketch, and it was successfully communicating with my LoRaWAN gateway, uploading atmospheric data to TheTHingsNetwork . I shelved the project and since then I have a new laptop, and cannot revive the SAMD21 node
to no avail.
Where can I find the correct drivers for my environment?
What is the properly way for me to install them?
Should I consider a different / newer SparkFun LoRa capable device such as the ExPlorable? Am I less apt to have a problem with the newer devices?
As an aside, I configured an Arduino IDE on my Raspberry Pi 4, and the device was recognized on the port, however some of the necessary libraries (such as something gccxxxx did not have a version for ARM 64 environment) so I was dead in the water on the RPi environment for this project.
In advance I want to thank anyone that can help me, and SparkFun for all their great products, sensors, boards, and tutorials.
