Hello all,
I am new to this forum and moderately new to microcontrollers. My goal is to continuously print the voltage readings from 6 load cells at once. I am using an Arduino Uno and the SparkX Qwiic 24 Bit ADC. I currently have the system functioning with one ADC and one loadcell but have two questions. My first question is can I take 2 differential measurements (using four channels total) at once using one ADC? and the second question is can I daisy chain 3 ADC together (assigning a different addresses to each ADC) and print readings to the serial monitor using the Arduino IDE?
I tried searching this topic but did not find anything specific to my setup. This is probably as much of an Arduino question as anything else, but I am not super familiar with object oriented programming so I’m not sure where to start. Thanks in advance for your input!
