I’ve got a project going using the NR-52 as a handsfree and music streaming in my car. Some problems with this that I can see:
the NR-52 outputs speaker +/- (which I believe is a differential audio signal?), but input to head unit is single-ended
the input to the head unit uses an Audio GND, isolated from bus & chassis ground lines
impedance mismatch of course
From my research, some solutions might be:
audio transformer for isolating the circuit from the audio lines
differential amplifier to convert the +/- to a single-ended signal
some combo of the above (differential isolation amplifier?)
Any of that on the right track? It’s bluetooth, so don’t need premium sound quality, but I don’t also want to have a sub-par signal. I should in theory be isolating the bus signal too, since it’s got it’s own GND separate from chassis as well…
Any recommendations? Order of isolation vs single-ended conversion? Any off-the-shelf solutions? Or is this all wrong?
fwiw, CD changer that I’m emulating output 850mV into 10kOhm (I think I’m reading that correctly…needs more research there too).
