I have bought SPG40 and connect to pHat for pi zero through Qwiic. I have attach other sensors veml6030 and BME680 and given addresses except SPG40. Please advice.
Thank you.
Thank you.
How many sensors are on the i2c bus? I’d guess you need to disable the pull-up resistors on the back of the board (can also be re-enabled by placing a solder blob to reconnect) https://learn.sparkfun.com/tutorials/ai … e-overview - there should usually only be one set of resistors active per i2c bus
Share a photo of the wiring/hookup if that doesn’t help
