SPI0
Hi
Can someone please send me some code on how to initialise the SPI0 to be a Master? I am using the LPC2148 and am trying to get it to talk to the SC16IS762 dual uart (it has an SPI bus interface)
Any help will be great!
I have code set up for SPI1 that uses a 2 MHz clock at my apartment. I can send it to you later today if you’d like. SPI1 and SPI0 aren’t that different, so you should be able to read between the lines enough to figure out what’s going on.
