Hi
I am running the example code for STHS34PF80 and connecting it BLE nano33
I connected SCL and SDA, and left CS and INT floating.
I read negative temperature and always reading presence even if it should not.
If I connect CS to ground, there is no data being read from the sensor.
Any clue what is going wrong ?
thanks
What example code are you running?
What are your connections on the arduino?
It may happen due to a wrong connection, jumper wire, or I2C address.
