I am attempting to use openocd (0.7.0-dev-00095-g27ad96e
(2012-12-07-17:13) under Linux) + ST-Link V1 + olimex STM32-H103 and
run into problems with the usb-interface.
When starting openocd I get an:
stlink_usb_open(): claim interface failed
Has someone a clue what I’m doing wrong?
plugged ST-Link:
Debug: 176 7 stlink_layout.c:43 stlink_layout_open(): stlink_layout_open
Debug: 177 7 stlink_usb.c:1152 stlink_usb_open(): stlink_usb_open
Debug: 178 7 stlink_usb.c:1167 stlink_usb_open(): transport: 1 vid: 0x0483 pid: 0x3744
Debug: 179 143 stlink_usb.c:1177 stlink_usb_open(): claim interface failed
Debug: 180 143 stlink_layout.c:50 stlink_layout_open(): failed
Debug: 181 143 command.c:631 run_command(): Command failed with error code -4
User : 182 143 command.c:669 command_run_line(): in procedure ‘transport’
Debug: 183 143 command.c:631 run_command(): Command failed with error code -4
User : 184 143 command.c:669 command_run_line(): in procedure ‘init’
Debug: 185 143 stlink_interface.c:99 stlink_interface_quit(): stlink_interface_quit
Compare to detached ST-Link:
Debug: 176 6 stlink_layout.c:43 stlink_layout_open(): stlink_layout_open
Debug: 177 6 stlink_usb.c:1152 stlink_usb_open(): stlink_usb_open
Debug: 178 6 stlink_usb.c:1167 stlink_usb_open(): transport: 1 vid: 0x0483 pid: 0x3744
Error: 179 140 stlink_usb.c:1170 stlink_usb_open(): open failed
Debug: 180 140 stlink_layout.c:50 stlink_layout_open(): failed
Debug: 181 140 command.c:631 run_command(): Command failed with error code -4
User : 182 140 command.c:669 command_run_line(): in procedure ‘transport’
Debug: 183 140 command.c:631 run_command(): Command failed with error code -4
User : 184 140 command.c:669 command_run_line(): in procedure ‘init’
Debug: 185 140 stlink_interface.c:99 stlink_interface_quit(): stlink_interface_quit
My openocd.cfg:
#daemon configuration###############################################################
telnet_port 4444
gdb_port 3333
#interface configuration############################################################
source [find interface/stlink-v1.cfg]
# didn'twork directly
# #board configuration################################################################
# source [find board/olimex_stm32_h103.cfg]
# board/olimex_stm32_h103.cfg
# Olimex STM32-H103 eval board
# http://olimex.com/dev/stm32-h103.html
# Work-area size (RAM size) = 20kB for STM32F103RB device
set WORKAREASIZE 0x5000
# source [find target/stm32f1x.cfg]
source [find target/stm32f1x_stlink.cfg]
(I build openocd with --enable-stlink and followed the advice to get
stlink ignored when connected).
Thank you!
Volker
