STM32F4 Discovery for STM32F429
Trying to setup openOCD on a STM32 F4 Discovery kit, I was faced with following errors (see listing next).
I currently use texane st-flash tool to flash the MCU, but st-util does not start, reporting an error (see issue https://github.com/texane/stlink/issues/322) on that same board.
Thanks in advance for your assistance.
Marc
$ openocd -f interface/stlink-v2.cfg -f board/stm32f429discovery.cfg
Open On-Chip Debugger 0.9.0 (2015-05-19-13:44)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Warn : Interface already configured, ignoring
Error: already specified hl_layout stlink
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
none separate
srst_only separate srst_nogate srst_open_drain connect_deassert_srst
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
Info : clock speed 1800 kHz
Info : STLINK v2 JTAG v17 API v2 SWIM v0 VID 0x0483 PID 0x3748
Info : using stlink api v2
Info : Target voltage: 2.882256
Error: jtag status contains invalid mode value - communication failure
Polling target stm32f4x.cpu failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
Info : Previous state query failed, trying to reconnect
Examination failed, GDB will be halted. Polling again in 300ms
Examination failed, GDB will be halted. Polling again in 700ms
Examination failed, GDB will be halted. Polling again in 1500ms
Examination failed, GDB will be halted. Polling again in 3100ms
Examination failed, GDB will be halted. Polling again in 6300ms
Please could somebody help, it is really frustrating to get stuck on setting up a dev environnement ? Thanks
I upgraded the ST Link firmware from Linux using the ST supplied Java package (V2.J17 => V2.J24). So it seems my hardware and Linux conf are OK.
However the problem remains the same:
$ openocd -f board/stm32f429discovery.cfg
none separate
Info : STLINK v2 JTAG v24 API v2 SWIM v0 VID 0x0483 PID 0x3748
Info : Target voltage: 2.885933
I think I found the reason. See http://nuttx.org/doku.php?id=wiki:howtos:jtag-debugging
