I am working with IAR EWARM and OpenOCD from SVN rev.1379M (see environment description at the end). Despite of several minor issues I try to live with, I came to a full stop:
while debugging mysterious BusFaults and HardFaults, I found that, when downloading compiled image from within EWARM IDE to FLASH, random runs of 16-byte sized blocks gets corrupted:
Tue Mar 03 01:23:16 2009: Loaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 5.4\arm\config\flashloader\ST\FlashSTM32F10xxx.mac
Tue Mar 03 01:23:17 2009: -I- execUserFlashInit!
Tue Mar 03 01:23:17 2009: 456 bytes downloaded and verified (0.98 Kbytes/sec)
Tue Mar 03 01:23:17 2009: Loaded debugee: C:\Program Files\IAR Systems\Embedded Workbench 5.4\arm\config\flashloader\ST\FlashSTM32F10xxxRAM16K.out
Tue Mar 03 01:23:17 2009: Target reset
Tue Mar 03 01:23:20 2009: Software reset was performed
Tue Mar 03 01:23:21 2009: 8164 bytes downloaded into FLASH and verified (1.91 Kbytes/sec)
Tue Mar 03 01:23:21 2009: Warning:
Verify error at address 0x080001D0, target byte: 0x90, byte in file: 0x01
Verify error at address 0x080001D1, target byte: 0x3D, byte in file: 0xD2
Verify error at address 0x080001D2, target byte: 0x00, byte in file: 0x01
Verify error at address 0x080001D3, target byte: 0x20, byte in file: 0xF0
Verify error at address 0x080001D4, target byte: 0x90, byte in file: 0x3F
Verify error at address 0x080001D5, target byte: 0x04, byte in file: 0xFB
Verify error at address 0x080001D6, target byte: 0x00, byte in file: 0x20
Verify error at address 0x080001D7, target byte: 0x08, byte in file: 0x46
Verify error at address 0x080001D8, target byte: 0x10, byte in file: 0xBD
Verify error at address 0x080001D9, target byte: 0x2E, byte in file: 0xE8
Verify error at address 0x080001DA, target byte: 0x00, byte in file: 0xF0
Verify error at address 0x080001DB, target byte: 0x20, byte in file: 0x87
Verify error at address 0x080001DC, target byte: 0x31, byte in file: 0xF8
Verify error at address 0x080001DD, target byte: 0x01, byte in file: 0xB5
Verify error at address 0x080001DE, target byte: 0x00, byte in file: 0x05
Verify error at address 0x080001DF, target byte: 0x20, byte in file: 0x46
Tue Mar 03 01:23:21 2009: Warning: There were warnings during download, see Log Window
Tue Mar 03 01:23:23 2009: Loaded debugee: D:\PROJECTS\TEST\Firmware\Debug\Exe\Firmware.out
Tue Mar 03 01:23:23 2009: Software reset was performed
Tue Mar 03 01:23:23 2009: Target reset
Data in 16-byte runs seem to be corrupted in random way - differs from download to download, although the offset is more-or-less constant. Furthermore, I tried to test my chips to ensure they were not damaged by issuing on telnet:
Open On-Chip Debugger
> reset halt
JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (Manufacturer: 0x23b, Part: 0xba00, Version: 0x3)
JTAG Tap/device matched
JTAG tap: stm32.bs tap/device found: 0x16410041 (Manufacturer: 0x020, Part: 0x6410, Version: 0x1)
target state: halted
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x08001ec4
> stm32x mass_erase 0
device id = 0x20006410
flash size = 128kbytes
stm32x mass erase complete
> flash erase_check 0
successfully checked erase state
# 0: 0x00000000 (0x400 1kB) erased
# 1: 0x00000400 (0x400 1kB) erased
# 2: 0x00000800 (0x400 1kB) erased
#125: 0x0001f400 (0x400 1kB) erased
#126: 0x0001f800 (0x400 1kB) erased
#127: 0x0001fc00 (0x400 1kB) erased
> flash fillw 0x08000000 0x12345678 32768
wrote 131072 bytes to 0x08000000 in 52.703125s (2.428699 kb/s)
> flash erase_check 0
# 0: 0x00000000 (0x400 1kB) not erased
# 2: 0x00000800 (0x400 1kB) not erased
# 3: 0x00000c00 (0x400 1kB) erased
# 4: 0x00001000 (0x400 1kB) not erased
# 5: 0x00001400 (0x400 1kB) erased
# 6: 0x00001800 (0x400 1kB) not erased
# 7: 0x00001c00 (0x400 1kB) erased
# 8: 0x00002000 (0x400 1kB) not erased
# 9: 0x00002400 (0x400 1kB) erased
# 10: 0x00002800 (0x400 1kB) not erased
# 11: 0x00002c00 (0x400 1kB) erased
# 12: 0x00003000 (0x400 1kB) not erased
# 13: 0x00003400 (0x400 1kB) erased
# 14: 0x00003800 (0x400 1kB) not erased
# 15: 0x00003c00 (0x400 1kB) erased
#122: 0x0001e800 (0x400 1kB) not erased
#123: 0x0001ec00 (0x400 1kB) erased
#124: 0x0001f000 (0x400 1kB) not erased
#126: 0x0001f800 (0x400 1kB) not erased
> dump_image flash_contents.dmp 0x08000000 131072
dumped 131072 byte in 7.875000s
>_
flash fillw filled consistently every second 1kb segment of FLASH. The file flash_contents.dmp confirms this. I can successfully fill the gaps with flash fillw 0x08000400 0x87654321 32512, and I get 1kb-blocks of 0x12345678 interleaved with same sized 0x87654321-filled blocks.
My environment is:
IAR EWARM 5.30.1 set up to use GDB debugger, XP Pro with latest FT2232 drivers (from ftdichip.com), oocd from SVN 1379M (modified not to #define ARMV7_GDB_HACKS), compiled with -mno_cygwin and ftd2xx.
config: arm-usb-ocd.cfg from SVN (tried jtag_khz 100 with no imrpvements), stm32x.cfg from SVN, with adjusted set _BSTAPID to suit my MCU.
HW: ARM-USB-OCD, 2x devel boards STM32-P103 from Olimex (STM32F103RBT6, rev.B), with separate TRST and SRST. Exactly the same issue is with my 3 other own boards with STM32F103CBT6, rev. Z.
I am keen on helping with testing to improve the quality of OpenOCD, so if I need to provide some additional info - just ask, I will do so. Unfortunately, I have had all kinds of problems with openocd already for about a year. I am updating OpenOCD constantly from SVN - some things improve, some things gets broken; sadly there is no working alternative to openocd, not necessarily free, but with sane price tag ![]()
Kind regards to all.[/code]
