Hello
I/we want to buy a development/evaluation board with either an ST STR911FM44X6 or STR912FW44X6 CPU (512K flash, 96K RAM; ethernet is not a requirement), including JTAG debugger (on-board or separate). (I’d like it to run with 96Mhz (24Mhz crystal) if possible.)
I would like it have working with OpenOCD, or alternatively in any other solid way so that I can work with GNU tools (in any case it must work for eCos, FreeRTOS or maybe NutOS). I much prefer working on Linux.
I need access to the cpu’s I/O ports for attaching other hardware (so e.g. the STR9-comStick from Hitex won’t do, I think).
Which ones have you got working and can you recommend?
Christian.
