I’m creating a PCB layout in EAGLE that uses the straddle mount USB connector seen below.
datasheet: http://portal.fciconnect.com/Comergent/ … 104109.pdf
digikey: http://www.digikey.com/product-search/e … 109-0001LF
Is there a way for me to create this as a single part in EAGLE such that it correctly places the solder pads on both sides of the board or do I need to make two separate representative “half” components, one for each side of the board?
