is the avr development board http://www.sparkfun.com/commerce/produc … ucts_id=33
programmed with the rs-232 port on the board or do you need a separate programmer to use with the ICSP port?
IF you put in an AVR pre-flashed with a bootloader, you could program it via the RS232 port, but otherwise you need an ICSP programmer.
I’d just get the ICSP programmer - they’re cheap.
Cheers,
–David Carne
I guess i will get a parallel programmer (supports Tiny13) and not that other board. :arrow:
