I’m here to ask for some suggestions on the development board choice. I’m fairly new to this field and a wide range of different chips from different vendors is a bit overwhelming.
I am looking for:
) hopefully a development board
) 802.15.4 compatible
) low power consumption
) will connect accelerometer, piezo sensor, capacitive touch sensor
) small to fit on the palm of a hand
What I am trying to achieve:
) battery-powered node
) on high readings from sensors sends to the base station
) hopefully sleeps most of the time
) distance up to 20 meters
Maybe you can point to your personal favorites that can be used to solve this.
