Perhaps this has been discussed in the past, but can you provide some guidance about using solar controllers like SunnyBuddy with LiPo batteries in weather stations that will invariably be exposed to sub-freezing temperatures? Should LiPo batteries be charged when it’s that cold, or should they even be used when it’s that cold? I know of at least one other solar charger/controllerr that uses a temperature sensor to stop charging the LIPo battery when it’s below freezing. Obviously this isn’t much of a solution for powering weather stations with LiPo batteries in temperate climates.
