Swarm M138 brakeout board
Is anyone else having issues sending messages to the Swarm Cloud dashboard? I have mine plugged in for a few days not and it’s not transmitting, RSSI is at -113. I am using USB C from my laptop with the python program provided. It states that I have messages waiting to transmit but nothing is being pushed out. Any ideas? :geek:
Hi codepanda,
Some things to check:
Does the antenna have a good view of the sky? It needs to be able to ‘see’ the satellites as they pass over.
Are you using the antenna ground plane?
If you enable the $RT messages, do you see the extra messages containing SNR and FDEV as each satellite passes?
It can sometimes take a few hours for the messages to be sent, depending on your location and the timing of the satellite orbits.
HI Paul thank you for getting back to me. Yeah I am using a ground plane. I think my issue is that I am not leaving it plugged in long enough to send. I will hook it to my laptop go outside then after an hour I will put it all away. I am working on a housing to get it outside and online. I also wanted to ask you about this “If you enable the $RT messages, do you see the extra messages containing SNR and FDEV as each satellite passes?” like in the python program or via terminal or Arduino ?
I get an error avrdude: stk500v2_ReceiveMessage(): timeout when uploading the example sketch (Example1_getConfigurationSettings). The Swarm_M138GUI works fine. What should be the settings for Board, Processor, and Programmer? I am using Arduino Mega, and AT Mega2560, and USBasp respectively. Turned off Norton360.
Thanks.
swarmuser
@codepanda:
Can you extend your antenna cable so the antenna and ground plane are outside - and the modem is inside? I have my antenna connected via 15m of RG58 coax cable and it still works well.
On the Python Gui, press the “Receive Test 1Hz” button to enable the $RT messages. Most display the background signal strength (RSSI) but you will get extra messages when a satellite passes overhead. These contain the Signal to Noise Ratio (SNR) and Frequency Deviation (FDEV - Doppler Shift) of the satellite signal. If you can see those then you know your antenna cable is OK (ruling out a broken cable or poor connection).
@swarmuser:
Please be careful. The AT Mega 2560 will be a 5V board. The modem requires 3.3V Tx and Rx signals. You may damage the modem if you connect it directly to a 5V board. You need to use a level-shifter:
https://learn.sparkfun.com/tutorials/sa … akout-pins
The board will be: Arduino AVR \ Mega 2560.
PaulZC,
Today at 3pm I got a sweet hot message from my device to the swarm cloud. I was not leaving it on long enough. Thank you for the help. :ugeek:
@codepanda:
No problem! The pass checker will give you an idea of when the next satellite pass will take place - and/or the best times of day to transmit:
https://kube.tools.swarm.space/pass-checker/
The “deadbands” will decrease as the Swarm constellation increases.
Hi
I am trying to use my modem to get some message to hive but so far no luck tried all possible things.
I have a doubt i am trying to get it to work from India. It is possible to get it work in india ?
Hello @pallavi,
India was not on the list of supported countries a few months ago:
“The current list of approved countries / regions for the M138 Modem is: Antarctica, Australia, Austria, Canada, Denmark, Germany, Greenland, Iceland, Ireland, Netherlands, New Zealand, Spain, Sweden, UK, US, and International Waters (12 nautical miles offshore).”
I will ask Swarm for an update.
Thanks for quick response.
Yes please update me for same
Hello @pallavi,
We have an updated list of supported countries from Swarm:
USA
Antarctica
Australia
Austria
Brazil
Canada
Colombia
Denmark
Georgia
Germany
Greenland
Iceland
Ireland
New Zealand
Netherlands
Spain
Sweden
United Kingdom
We do not know if/when India will be supported.
If you would like to return your M138 board, please enter your details here:
https://www.sparkfun.com/returns
Very best wishes - and apologies for the inconvenience,
