Telnet Into a Telit Module
I need to do the opposite from what everyone else seems to be trying to do. I need to telnet into the module and get a gprs to serial gateway setup. Unlike more people we are building a large system and will have a custom apn with custom addresses attached to our network. This means I will know what every devices IP address is.
I am totally lost as how to make the telit module listen for traffic and respond by passing that out to the attached device and sending back the response. Ideas? Help? I’m running out of patience, time, and sanity…
Made some progress. #SL lets you setup the telit to listen to a port and #scfgext can let you autoanswer but I still get errors with that command. #SA answers the data call. #FRWL needs to be configured to let the IP in as well.
