test leads (clips) for tqfp-80 chip
I have a TQFP-80 chip and want to hook some leads up to it for testing. My current test leads are too large. I am looking for recommendations that will work that arent too expensive and arent too cheap (meaning they should last at least the duration of the project and hopefully several more).
The exact measurements of the chip pins are (nominal)
0.65 mm center to center
0.32 mm pin width
0.33 mm spacing
0.17 mm thick
Leads should be 0.2mm give or take. Digikey has exactly one set but they want $550 and I would rather not.
Given their size I am afraid of some cheaper leads breaking if a gnat lands on them.
