I purchased the EM-406A GPS receiver a while back and I wanted to report what I found.
This receiver has unbelievable tracking. I work in the basement of my 3 story house. It’s nearly impossible to make this module loose lock from the satellites. I even ran an experiment where I pushed a piece of aluminum foil over the top antenna side. Bottom side was laying on the table, so it wasn’t a total Gaussian shield.
Still, it stayed locked, although barely. It only lost lock when I pressed the foil down with my hands in place over top of it and leaned my body over the whole setup.
It was also very easy to use… power, ground & data is all you really need. Standard NMEA sentence output. I warm-start the module all the time (i.e. it’s had a lock recently, but I power down & back up again). It warm-starts & locks in just a few seconds.
- Bart
