Code
from machine import UART,Pin
from time import sleep
import _thread
import rp2
from array import array
import ascii_ku
import speed_motor
from os import uname
#import sys
uart1 = UART(0, baudrate = 115200, tx =Pin(0), rx = Pin(1))
floor1 = ['f', 'l', 'o', 'o', 'r','1']
floor2 = ['f', 'l', 'o', 'o', 'r','2']
floor3 = ['f', 'l', 'o', 'o', 'r','3']
button_cmd = [16,1]
selector_cmd = [16,129]
print(uname()[0])
delaytime = 0.0000001 # Printer clock delay
coin = Pin(22, Pin.IN,Pin.PULL_UP)
coin_num = 0
motor = speed_motor.motor_control(2, 3, 4, 5) # Initialize the printer's internal stepper motor pins, corresponding to the a+/a-/b+/b- of the stepper motor
mov_bit = 0
PRINTER_DIN = Pin(20, Pin.OUT)
PRINTER_CLK = Pin(19, Pin.OUT)
PRINTER_LAT = Pin(18, Pin.OUT, Pin.PULL_UP)
STB1 = Pin(6, Pin.OUT, Pin.PULL_DOWN)
STB2 = Pin(7, Pin.OUT, Pin.PULL_DOWN)
STB3 = Pin(8, Pin.OUT, Pin.PULL_DOWN)
STB4 = Pin(9, Pin.OUT, Pin.PULL_DOWN)
STB5 = Pin(14, Pin.OUT, Pin.PULL_DOWN)
STB6 = Pin(15, Pin.OUT, Pin.PULL_DOWN)
lock = _thread.allocate_lock()
ascii_code = ascii_ku.ascii_code() # Importing an ascii character library
# shuru = 'aa'
# line_word = []
# for item in range(len(shuru)):
#     line_word.append(shuru[item])
# line_num = len(shuru)
# bottom_line_num = len(shuru)%
# global motor_speed = 0
# global line = 0
# if len(shuru) > 6:
#     motor_speed = len(shuru) % 6
#     if (len(shuru) % 6) == 0:
#         motor_speed = 12
# else:
# # print(motor_speed)
# line = (len(shuru) // 12) + 1
# if (len(shuru) % 12) == 0:
#     line -= 1
lins = 0
supper = 0
slower = 0
danjia = 0
# _thread.start_new_thread(motor.run_stop, (0.005*motor_speed, 26*line))
# _thread.start_new_thread(motor.run_stop, (motor_speed, line))
# _thread.start_new_thread(motor.run_stop, (0.03, 56))
def pay(pay):
    global coin_num
    line_word = {'line_word1':['s','i','t','e',':','F','1','-','0'],'line_word2':['0','d','a','y','2','h','o','u','r'],'line_word3':['t','o','t','a','l',':','4','.','0'],'line_word4':['T','o','t','a','l',':','4','.','0']}
    line_wors = {'line_word1':['U','n','i','t',':','2','.','0','0'],'line_word2':['T','o','t','a','l',':','4','.','0'],
                 'line_word3':['U','n','i','t',':','2','.','0','0'],'line_word4':['T','o','t','a','l',':','5','.','0']}
#     line_word1 = ['S','i','t','e',':','F','1','-','0']
#     line_word2 = ['1','D','a','y','1','H','o','u','r']
#     line_word3 = ['U','n','i','t',':','2','.','0','0']
#     line_word4 = ['T','o','t','a','l',':','5','.','0']
#     line_word1[8]=str(pay[0])
#     line_word2[0]=str(pay[1])
#     line_word2[4]=str(pay[2])
#     line_word4[6]=str(pay[3])
    (line_word['line_word1'])[8]=str(pay[0])
#     (line_word['line_word2'])[0]=str(pay[1])
#     (line_word['line_word2'])[4]=str(pay[2])
#     (line_word['line_word4'])[6]=str(pay[3])
    sleep(1)
    uart1.write('ST<{"cmd_code":"set_value","type":"image_value","widget":"image_value4","value":'+str(pay[3])+'}>ET')
#     sleep(2)
#     print(line_word.get('line_word'+str(1))[0])
#     print('zfdszfz',line_word)
#     sleep(2)
#     uart1.write('ST<{"cmd_code":"set_text","type":"edit","widget":"message5","text":"F1 - '+pay[0]+'"}>ET')
#     uart1.sendbreak()
#     sleep(1)
#     uart1.write('ST<{"cmd_code":"set_text","type":"edit","widget":"message6","text":"'+str(pay[1])+'"}>ET')
#     uart1.sendbreak()
#     sleep(1)
# #     uart1.write('ST<{"cmd_code":"set_text","type":"edit","widget":"message22","text":"'+str(pay[2])+'"}>ET')
#     uart1.write('ST<{"cmd_code":"set_text","type":"edit","widget":"message8","text":"'+str(pay[3])+'"}>ET')
    while True:
        if coin.value()==0:
            coin_num += 1
            print("Number of coins deposited:",coin_num)
            sleep(0.1)
            uart1.write('ST<{"cmd_code":"set_value","type":"image_value","widget":"image_value2","value":'+str(coin_num)+'}>ET')
            if coin_num == pay[3]:
                uart1.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"image37","visible":true}>ET')
        if uart1.any()>1:
            rx2 = []
            data_name2 = ''
            bin_data = uart1.read(40)
            uart1.sendbreak()
            rx1 = list(bin_data)
            for item in rx1:
                rx2.append(chr(item))
            print(rx2)
            if rx1[3:5:1] == button_cmd:
                data_name_len = rx1[6] - 1
                data_name = rx2[7:data_name_len+6:1]
                data_name2 = ''.join(data_name)
                print(data_name2)
                if data_name2 == 'back':
                    break
                elif data_name2 == 'print' and coin_num == pay[3] and rx1[13] == 2:
                    data_name2=''
                    _thread.start_new_thread(motor.run_stop, (9, 4))
                    for iii in range(1,3):
                        for linss in range(32):
                            supper=slower=0
                            for lins in range(9):
#                                 temp_list=ascii_code.code.get(('line_word'+str(iii))[lins])
#                                 print(temp_list,type(temp_list))
                                if (line_word.get('line_word'+str(iii))[lins]).islower():
                                    word_size24 (ascii_code.code.get(line_word.get('line_word'+str(iii))[lins]), linss%32, lins%12, supper, slower)
                                    slower += 1
                                else:
                                    last_word_size32 (ascii_code.code.get(line_word.get('line_word'+str(iii))[lins]), linss%32, lins%12, supper, slower)
                                    supper += 1
                        sleep(6)
#                     for iii in range(1,2):
#                         for linss in range(32):
#                             supper=slower=0
#                             for lins in range(9):
# #                                 temp_list=ascii_code.code.get(('line_word'+str(iii))[lins])
# #                                 print(temp_list,type(temp_list))
#                                 if (line_wors.get('line_word'+str(iii))[lins]).islower():
#                                     word_size24 (ascii_code.code.get(line_wors.get('line_word'+str(iii))[lins]), linss%32, lins%12, supper, slower)
#                                     slower += 1
#                                 else:
#                                     last_word_size32 (ascii_code.code.get(line_wors.get('line_word'+str(iii))[lins]), linss%32, lins%12, supper, slower)
#                                     supper += 1
#                     sleep(6)
#                             supper=slower=0
#                                     slower += 1
#                                 else:
#                                     supper += 1
def floor1def():
    day_jia = 0
    hour_jia = 0
    day_flag = False
    hour_flag = False
    price_flag = False
    posltion = False
    zongjia = 0
    pay1 = [0,0,0,0]
    print("floor1 now")
#     uart1.write('ST<{"cmd_code":"set_text","type":"edit","widget":"message3","text":"2.00$/H"}>ET')
    uart1.sendbreak()
    while True:
        if uart1.any()>1:
            rx2 = []
            data_name2 = ''
            uart1.sendbreak()
            for item in rx1:
            print(rx2)
                print(data_name2)
                    break
                elif data_name2 == 'position':
                    posltion = True
                    pay1[0]=rx2[15]
                    write1(rx2[15])
                elif data_name2 == 'pay' and posltion and price_flag:
                    uart1.write('ST<{"cmd_code":"open_win","type":"window","widget":"window7"}>ET')
                    pay(pay1)
#                 if data_name2 == 'pay' and posltion = True and (day_flag or hour_flag):
#                     posltion = True
#                     uart1.write('ST<{"cmd_code":"open_win","type":"window","widget":"window7"}>ET')
            if rx1[3:5:1] == selector_cmd:
                data_name_len = rx1[6] - 4
                data_name = rx2[7:data_name_len+7:1]
                print(data_name2)
                if data_name2 == 'time_day1':
                    pay1[1]=rx2[19]
                    write2(ord(rx2[19]))
                    day_jia = ord(rx2[19])
                    day_flag = True
                elif data_name2 == 'time_hour1':
                    pay1[2]=rx2[20]
                    write3(ord(rx2[20]))
                    hour_jia = ord(rx2[20])
                    hour_flag = True
            if hour_flag or day_flag:
                price_flag = True
                zongjia = (day_jia*48) + (hour_jia*2)
                pay1[3]=zongjia
                print(str(zongjia))
                uart1.write('ST<{"cmd_code":"set_text","type":"edit","widget":"message4","text":"'+str(zongjia)+'"}>ET')
                hour_flag = day_flag = False
def floor2def():
    pass
def floor3def():
    pass
def write1(num):
    #print(ss)
    for item in range(49,55):
        uart1.write('ST<{"cmd_code":"set_image","type":"image","widget":"image1_'+chr(item)+'","image":"nocar_bg"}>ET')
    uart1.write('ST<{"cmd_code":"set_image","type":"image","widget":"image1_'+num+'","image":"selectedcar_bg2"}>ET')
    uart1.write('ST<{"cmd_code":"set_text","type":"edit","widget":"message1","text":"F1 - '+num+'"}>ET')
def write2(num):
#     danjia = 1
    uart1.write('ST<{"cmd_code":"set_text","type":"edit","widget":"message2","text":"'+str(num)+'"}>ET')
#     if danjia == 1:
def write3(num):
#     danjia = 1
    uart1.write('ST<{"cmd_code":"set_text","type":"edit","widget":"message22","text":"'+str(num)+'"}>ET')
#     if danjia == 1:
def last_word_size32 (word_line, linss, lins, supper, slower):
    for mov_bit in range((supper*32)+(slower*24)):
        PRINTER_CLK.value(0)
        sleep(delaytime)
        PRINTER_DIN.value(0)
        PRINTER_CLK.value(1)
        sleep(delaytime)
    for mov_bit in range(31, -1, -1):
        word_bit = (word_line[linss] >> mov_bit)&0b00000000000000000000000000000001
        sleep(delaytime)
        PRINTER_DIN.value(word_bit)
        sleep(delaytime)
    for mov_bit in range(352-((supper*32)+(slower*24))):
        sleep(delaytime)
        sleep(delaytime)
    if (supper*32)+(slower*24) < 192:
        PRINTER_LAT.value(0)
        STB1.value(1)
        STB2.value(1)
        STB3.value(1)
        STB4.value(1)
        sleep(0.005)
        STB1.value(0)
        STB2.value(0)
        STB3.value(0)
        STB4.value(0)
        PRINTER_LAT.value(1)
    else:
        STB4.value(1)
        STB5.value(1)
        STB6.value(1)
        sleep(0.005)
        STB4.value(0)
        STB5.value(0)
        STB6.value(0)
#         PRINTER_LAT.value(0)
#         STB1.value(1)
#         STB2.value(1)
#         STB3.value(1)
#         STB4.value(1)
#         STB5.value(1)
#         STB6.value(1)
#         sleep(0.005)
#         STB1.value(0)
#         STB2.value(0)
#         STB3.value(0)
#         STB4.value(0)
#         STB5.value(0)
#         STB6.value(0)
#         PRINTER_LAT.value(1)
def word_size24 (word_line, linss, lins, supper, slower):
        sleep(delaytime)
        sleep(delaytime)
    for mov_bit in range(23, -1, -1):
        word_bit = (word_line[linss] >> mov_bit)&0b000000000000000000000001
        sleep(delaytime)
        sleep(delaytime)
    for mov_bit in range(360-((supper*32)+(slower*24))):
        sleep(delaytime)
        sleep(delaytime)
        STB1.value(1)
        STB2.value(1)
        STB3.value(1)
        sleep(0.005)
        STB1.value(0)
        STB2.value(0)
        STB3.value(0)
    else:
        STB4.value(1)
        STB5.value(1)
        STB6.value(1)
        sleep(0.005)
        STB4.value(0)
        STB5.value(0)
        STB6.value(0)
#         STB1.value(1)
#         STB2.value(1)
#         STB3.value(1)
#         STB4.value(1)
#         STB5.value(1)
#         STB6.value(1)
#         sleep(0.005)
#         STB1.value(0)
#         STB2.value(0)
#         STB3.value(0)
#         STB4.value(0)
#         STB5.value(0)
#         STB6.value(0)
while True:
    if uart1.any()>1:
        rx2 = []
        data_name2 = ''
        uart1.sendbreak()
        for item in rx1:
        print(rx2)
        if rx2[7:13:1] == floor1:
            floor1def()
        elif rx2[7:13:1] == floor2:
            floor2def()
        elif rx2[7:13:1] == floor3:
            floor3def()
    supper=slower=0
    if linss < 32:
        for lins in range(len(line_word)):
#             if lins//12:
#                 break
            if (line_word[lins].isupper() or line_word[lins].isdigit() or line_word[lins].isspace()):
                last_word_size32 (ascii_code.code.get(line_word[lins]), linss%32, lins%12, supper, slower)
                supper += 1
            elif (line_word[lins].islower()):
                word_size24 (ascii_code.code.get(line_word[lins]), linss%32, lins%12, supper, slower)
                slower += 1
    else:
        if linss == 32:
            sleep(5.8)
        for lins in range(motor_speed):
            if (line_word[lins].isupper()):
                last_word_size32 (ascii_code.code.get(line_word[12]), linss%32, lins%12, len(line_word))
#     elif:
#         for lins in range(len(line_word)):
#             if (line_word[lins].isupper()):
#                 last_word_size32 (ascii_code.code.get(line_word[lins]), linss, lins, len(line_word))
line_word.clear()
