Hi
I have a digispark Tiny AVR Programmer an I plugged in a 8 pin Attiny85 with the notch on the same side as in the white PCB outline.
I “believe” I have followed the instructions at the hookup guide ( https://learn.sparkfun.com/tutorials/ti … ic-install). I am up to uploading a sketch and I get an error
An error occurred while uploading the sketch
avrdude: Expected signature for ATtiny85 is 1E 93 0B
Double check chip, or use -F to override this check.
Wrong microcontroller found. Did you select the right board from the Tools > Board menu?
In device manager I have “libusb-win32 devices - FabISP” driver installed, I used the Zadig tool, I uninstalled and reinstalled a few times
I have loaded the damellis add-on git hub files in the hardware folder of Arduino (https://github.com/damellis/attiny)
I have gone into boards manager and installed “attiny by David A mellis”
In Adruino IDE 1.8.15 I selected
Boards: “ATtinny 25/45/85”
Processor: “Atinny85”
Clock “internal 1Mhz”
Com 1 is ticked, but I believe this is irrelevant
Programmer “USBtinyISP”
I have clicked the “Load bootloader” and I get the same error
I have managed to load the LED blink sketch software on the “Digispark ATTINY85 Arduino Compatible Board” with the Attiny already soldered onto it. I believe these boards already have a bootloader loaded and thus it connects.
Any ideas/solutions of the error please?
