I have a SparkFun module with the F9P. I’m having an issue when I pull EXTINT0 low with just a resistor. If I solder a resistor as shown in the attachment then I don’t get any data output.
If I replace the resistor with a decade box with a value of 20kΩ then I start seeing data being output, which is what I want. Why does just using a resistor not work and the decade box does work? I can see that I stand to learn something here and welcome any assistance.
Regards,
Chris
