I’m using a sparkfun pro micro for a few days now, i uploaded many sketches to it. Today after one upload i maybe stopped the upload mid-time (pressing upload while it was uploading) or i don’t know what happend but now i’m unable to upload any sketch to it. It is the 5v modell. I tried with different usb cables and different usb port on the computer. When i plug it in i get a port for a few seconds named “usbmodem” but after that the port disappears. I tried the reset pin grounding twice method but i only get the same “usbmodem” port after that too. I attached the full log in a txt file.
Error log.txt (19.7 KB)
Few rows of it:
avrdude: ser_drain(): read error: Device not configured
avrdude: ser_send(): write error: Device not configured
avrdude: ser_recv(): read error: Device not configured
avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = “”; type =
Software Version = .; Hardware Version = .
a kiválasztott soros port Software Version = .; Hardware Version = .
nem létezik vagy az alaplap nincs csatlakoztatva
avrdude: error: buffered memory access not supported. Maybe it isn’t
a butterfly/AVR109 but a AVR910 device?
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
avrdude: ser_close(): can’t reset attributes for device: Device not configured
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodem9, /dev/cu.usbmodemFA131, /dev/cu.usbmodemFD121, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodem9, /dev/tty.usbmodemFA131, /dev/tty.usbmodemFD121, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodem9, /dev/cu.usbmodemFA131, /dev/cu.usbmodemFD121, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodem9, /dev/tty.usbmodemFA131, /dev/tty.usbmodemFD121, } => {}
Uploading using selected port: /dev/cu.usbmodemFA131
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -P/dev/cu.usbmodemFA131 -b57600 -D -Uflash:w:/var/folders/m1/3vsby4b100sdzl9w48tnqnw80000gn/T/arduino_build_719231/Blink.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is “/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf”
User configuration file is “/Users/bencefabian/.avrduderc”
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodemFA131
Using Programmer : avr109
Overriding Baud Rate : 57600
avrdude: ser_open(): can’t open device “/dev/cu.usbmodemFA131”: No such file or directory
avrdude done. Thank you.
Could someone help me find a solution to revive my board?
