Triad Spectroscopy Sensor - direct instead of indirect light
I have been looking for a way to measure the radiant flux power received by a surface. It seems this device is able to measure radiant flux (W/cm2) but through a reflection of light from the onboard LEDs.
Can I point an LED directly at these sensors or is it required to be diffused through a reflection? I understand I would need to have the LED be far enough away to not saturate the sensors.
