i have problem, i can’t transmit and receive data. can anyone help me
this my transmit source code:
$regfile = “8535def.dat”
$baud = 9600
$crystal = 12000000
Ce Alias Portc.4
Cs Alias Portc.3
Dr Alias Pinc.2
Clk Alias Portc.1
Dat Alias Portc.0
Dat_pin Alias Pinc.0
Declare Sub Config_fullmode
Declare Sub Send_byte
Declare Sub Read_byte
Declare Sub Config_tr
Declare Sub General_config
Config Pinc.4 = Output
Config Pinc.3 = Output
Config Pinc.2 = Input
Config Pinc.1 = Output
Config Pinc.0 = Output
Dim Jumlah As Byte
Dim Dat_out As Byte
Dim I As Byte
Dim J As Byte
Dim Data_print As Bit
'shockburst configuration
Dim Data2_w As Byte , Data1_w As Byte
Dim Addr2_1 As Byte , Addr2_2 As Byte , Addr2_3 As Byte , Addr2_4 As Byte , Addr2_5 As Byte
Dim Addr1_1 As Byte , Addr1_2 As Byte , Addr1_3 As Byte , Addr1_4 As Byte , Addr1_5 As Byte
Dim Addr_w As Byte , Crc_length As Bit , Crc_en As Bit '6-1-1
'general configuration
Dim Rx2_en As Bit , Cm As Bit , Rfdr_sb As Bit , Xo_f As Byte , Rf_pwr As Byte '1-1-1-3-2
Dim Rf_ch As Byte , Rx_en As Bit '7-1
Dim Dat0 As Byte
Ce = 0
Cs = 0
Clk = 0
Dat = 0
Waitms 500
Data2_w = 8
Data1_w = 8 'length data
Addr2_5 = &H00
Addr2_4 = &H00
Addr2_3 = &H00
Addr2_2 = &H00
Addr2_1 = &H00
Addr1_5 = &H00 'address
Addr1_4 = &H00
Addr1_3 = &H00
Addr1_2 = &H00
Addr1_1 = &H00
Addr_w = 40 'length address
Crc_length = 1 'lenght crc
Crc_en = 1
Rx2_en = 0
Cm = 1 'direct/shockburst
Rfdr_sb = 1 'data rate kbps/mbps
Xo_f = 3 'crystal freq
Rf_pwr = 2 'db
Rf_ch = &H55 '0-83
Rx_en = 1
Call Config_fullmode
Waitms 10
Goto Kirim
Kirim: 'sub send
Rx_en = 0
Call Config_tr
'Kirim2:
Do
Dat0 = &H01
Ce = 0
Cs = 0
Waitus 10
Ce = 1
Waitus 10
Dat_out = Addr1_1 'addr1
Call Send_byte
Dat_out = Addr1_2 'addr2
Call Send_byte
Dat_out = Addr1_3 'addr3
Call Send_byte
Dat_out = Addr1_4 'addr4
Call Send_byte
Dat_out = Addr1_5 'addr5
Call Send_byte
Dat_out = Dat0 'data
Call Send_byte
Waitus 10
Ce = 0
Loop
End
Sub Config_tr
Cs = 1
Ce = 0
Config Dat_pin = Input
Waitms 10
Dat = Rx_en
Waitus 1
Clk = 1
Waitus 1
Clk = 0
Cs = 0
End Sub
Sub Send_byte
For I = 1 To 8
Waitus 1
'Ce = 0
Clk = 1
Rotate Dat_out , Left
Data_print = Dat_out And 1
’ Print Data_print;
Dat = Data_print
Waitus 1
'Ce = 1
Clk = 0
Next
Clk = 0
’ Print “”
End Sub
Sub Config_fullmode
Cs = 1
Ce = 0
Config Dat_pin = Output
Waitms 10
Dat_out = Data2_w
Call Send_byte
Dat_out = Data1_w
Call Send_byte
Dat_out = Addr2_5
Call Send_byte
Dat_out = Addr2_4
Call Send_byte
Dat_out = Addr2_3
Call Send_byte
Dat_out = Addr2_2
Call Send_byte
Dat_out = Addr2_1
Call Send_byte
Dat_out = Addr1_5
Call Send_byte
Dat_out = Addr1_4
Call Send_byte
Dat_out = Addr1_3
Call Send_byte
Dat_out = Addr1_2
Call Send_byte
Dat_out = Addr1_1
Call Send_byte
Shift Addr_w , Left , 1
Addr_w = Addr_w Or Crc_length
Dat_out = Addr_w Or Crc_en
Call Send_byte
Dat_out = Rx2_en
Shift Dat_out , Left , 1
Dat_out = Dat_out Or Cm
Dat_out = Dat_out Or Rfdr_sb
Shift Dat_out , Left , 3
Dat_out = Dat_out Or Xo_f
Shift Dat_out , Left , 2
Dat_out = Dat_out Or Rf_pwr
Call Send_byte
Dat_out = Rf_ch
Dat_out = Dat_out Or Rx_en
Call Send_byte
Cs = 0
End Sub
and receive source code:
$baud = 9600
$crystal = 12000000
Ce Alias Portd.6
Cs Alias Portd.5
Dr Alias Pind.4
Clk Alias Portd.3
Dat Alias Portd.2
Dat_pin Alias Pind.2
Declare Sub Geser
Config Lcd = 16 * 2
Config Lcdpin = Pin , Rs = Portc.1 , E = Portc.3 , Db4 = Portc.4 , Db5 = Portc.5 , Db6 = Portc.6 , Db7 = Portc.7
Config Pind.6 = Output
Config Pind.5 = Output
Config Pind.4 = Input
Config Pind.3 = Output
Config Pind.2 = Output
'Config Portb = Output
Dim Jumlah As Byte
Dim Dat_out As Byte
Dim I As Byte
Dim J As Byte
Dim N As Byte , X As Byte
Dim Dat0 As Byte
Cls
Ce = 0
Cs = 0
Clk = 0
Dat = 0
Waitms 500
Data2_w = 8
Data1_w = 8 ’
Addr2_5 = &H00
Addr2_4 = &H00
Addr2_3 = &H00
Addr2_2 = &H00
Addr2_1 = &H00
Addr1_4 = &H00
Addr1_3 = &H00
Addr1_2 = &H00
Addr1_1 = &H00
Addr_w = 40 ’
Crc_length = 1 ’
Crc_en = 1
Rx2_en = 0
Rf_pwr = 1 'db
Rf_ch = &H55 '0-83
Rx_en = 1
Waitms 10
Goto Terima
Terima:
Rx_en = 1
Call Config_tr
Waitms 10
Do
Cs = 0
Ce = 1
Waitus 10
While Dr = 0
Wend
Ce = 0
While Dr = 1
Call Read_byte
If Dat_out = &H01 Then
Cls
Lcd “terima”
Goto Terima
End If
Wend
Loop
Sub Read_byte
Dat_out = 1
For I = 1 To 8
Waitus 1
Clk = 1
Dat_out = Dat_out Or Dat_pin
Waitus 1
Clk = 0
Next
Clk = 0
End Sub
Sub Config_tr
Cs = 1
Ce = 0
Waitms 10
Dat = Rx_en
Waitus 1
Clk = 1
Waitus 1
Clk = 0
Cs = 0
End Sub
Sub Config_fullmode
Cs = 1
Ce = 0
Waitms 10
Dat_out = Data2_w
Call Send_byte
Dat_out = Data1_w
Call Send_byte
Dat_out = Addr2_5
Call Send_byte
Dat_out = Addr2_4
Call Send_byte
Dat_out = Addr2_3
Call Send_byte
Dat_out = Addr2_2
Call Send_byte
Dat_out = Addr2_1
Call Send_byte
Dat_out = Addr1_5
Call Send_byte
Dat_out = Addr1_4
Call Send_byte
Dat_out = Addr1_3
Call Send_byte
Dat_out = Addr1_2
Call Send_byte
Dat_out = Addr1_1
Call Send_byte
Call Send_byte
Dat_out = Rx2_en
Call Send_byte
Dat_out = Rf_ch
Call Send_byte
Cs = 0
End Sub
End
please help me, and what wrong in my program?
