Trying to get 4x4 pad to randomly blink off, then back on ag
Hello everyone.
I am new to the Arduino world, and have recently purchased a Sparkfun 4x4 LED keypad, controlled by an Arduino Mega 2560.
I would like to code it so that the LEDs randomly blink off, then back on again. Not one at a time, but have them completely random (so maybe as three to five or so blink off at the same time sometimes).
The code that I have to light them up is off of the Sparkfun tutorial page:
red-only.ino
Byron Jacquot @ SparkFun Electronics
1/6/2015
Example to drive the red LEDs in the RGB button pad.
Exercise 1 in a series of 3.
https://learn.sparkfun.com/tutorials/bu … hrome-leds
Development environment specifics:
Developed in Arduino 1.6.5
For an Arduino Mega 2560
This code is released under the MIT License.
Distributed as-is; no warranty is given.
//config variables
#define NUM_LED_COLUMNS (4)
#define NUM_LED_ROWS (4)
#define NUM_COLORS (1)
// Global variables
static bool LED_buffer[NUM_LED_COLUMNS][NUM_LED_ROWS];
static int32_t next_advance;
static uint8_t led_index;
static const uint8_t ledcolumnpins[NUM_LED_COLUMNS] = {42,43,44,45};
static const uint8_t colorpins[NUM_LED_ROWS] = {22,30,33,36};
static void setuppins()
uint8_t i;
// initialize all of the output pins
// LED column lines
for(i = 0; i < NUM_LED_COLUMNS; i++)
pinMode(ledcolumnpins*, OUTPUT);*
// with nothing selected by default
digitalWrite(ledcolumnpins, HIGH);
// LED row lines
for(i = 0; i < NUM_LED_ROWS; i++)
pinMode(colorpins, OUTPUT);
// with nothing driven by default
digitalWrite(colorpins, LOW);
static void scan()
static uint8_t current = 0;
uint8_t val;
uint8_t i, j;
// Select a column
digitalWrite(ledcolumnpins[current], LOW);
// write the row pins
if(LED_buffer[current])
digitalWrite(colorpins, HIGH);
delay(1);
digitalWrite(ledcolumnpins[current], HIGH);
// Move on to the next column
current++;
if (current >= NUM_LED_COLUMNS)
current = 0;
void setup()
// put your setup code here, to run once:
Serial.print(“Starting Setup…”);
// setup hardware
setuppins();
// init global variables
next_advance = millis() + 1000;
led_index = 0;
// Initialize the LED display array
for(uint8_t i = 0; i < NUM_LED_COLUMNS; i++)
for(uint8_t j = 0; j < NUM_LED_ROWS; j++)
LED_buffer[j] = false;
// Set the first LED in the buffer on
LED_buffer[0][0] = true;
Serial.println(“Setup Complete.”);
void loop()
// put your main code here, to run repeatedly:
scan();
if(millis() >= next_advance)
next_advance = millis()+1000;
LED_buffer[led_index/NUM_LED_COLUMNS][led_index%NUM_LED_COLUMNS] = false;
led_index++;
led_index %= (NUM_LED_COLUMNS * NUM_LED_ROWS);
LED_buffer[led_index/NUM_LED_COLUMNS][led_index%NUM_LED_COLUMNS] = true;
Any and all help would be much appreciated.
P.C.
Never used the keypad, but here is logic to turn LEDs randomly on or off at random times
// 16 LEDs in matrix
bool _led[] = {false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false};
void loop()
    // Random time interval
    int until = random(5000);
    delay(until);
    // How many LEDs to change state (at least 1)
    int amount = random(1,16);
    // Which LEDs to change state
    for (int i = 0; i < amount; i++)
        // Toggle random LED
        int which = random(16);
        _led[which-1] = _led[which-1] ? false : true;
        digitalWrite(which-1, _led[which-1]);
        char buffer[20];
        sprintf(buffer,"LED %d, state %d\n\n",which-1, _led[which-1]);
        Serial.println(buffer);
Completely untested, but should work.
