Trying to use library for SPX-17115 (Serial Flash - 128Mbit) for same family chip Winbond(W25N01G)
Hi, Paul (and Nathan).
Thank you for offering a library for the Serial Flash chip - 128mb W25Q128JV. I wonder if this same library would work for a bit of a larger capacity Flash (W25N01G).
I’ve used Teensy 4.1 board with same chip but I know their library won’t work for Artemis board.
https://github.com/PaulStoffregen/Littl … /README.md
Again thank you for your libraries!
Looking at the INSTRUCTIONS in the datasheets for the two chips, I am seeing several differences. The way the chip is erased looks very different: Chip Erase on the Q128 vs. Block Erase on the N01. The read addressing looks different too: 24-bit on the Q128 vs. 16-bit column addressing on the N01 (when BUF=1).
I think the library will not work correctly and would need to be modified for the N01…
Paul,
Thank you for your advice. I will check the code thoroughly. Perhaps Sparkfun can add flash drives with a higher capacity to its product list in the near future!
