The micro SD card slot on my Tsunami Super WAV Trigger qwiic will no longer latch onto an SD card when it’s inserted. As far as I can tell, there’s nothing broken in there, but the SD cards just pop right back out. Is there some way to get it re-engage? Obviously the Tsunami is useless without it.
Is this on a recent purchase?
This product doesn’t require a working latch, it uses a friction/tension fit. Might not be ideal but I’ve had success fixing similar with - I just leave the ‘sniffer’ inserted and swap SD cards at the other end.
I bought it in May 2025. It definitely is not a friction fit—it’s the type with a spring inside.
The product I linked is a friction fit…I’ve used them for this very reason. The spring no longer matters…it just stays in the Tsunami and you swap cards in the sniffer’s sd card holder
OK, thanks. I’ll give that a try.
Right on - in one case I had needed to hot-glue the sd sniffer into the tsunami (I chose hot glue because it was easy to undo). I held it in pace with 2 dabs of glue bridging the two pcbs (toward the edge, not by the metal holder)
