Two max98357A for stereo output through TRRS connector
That’s possible, fortunately the boards are inexpensive so getting two more won’t be much of an issue.
What I’d do first though would be to reflow your existing header pins and clean all the flux off the board so you can carefully inspect the jumpers. You might get lucky and things will work again.
Use some rubbing alcohol and an old toothbrush to clean the flux off. Make sure the board is completely dry before applying power.
