UBLOX ZED data conversion
Following your sample code. I am getting lat and lon data. But after I divide them by 10,000,000. The last few digit were zero out. Please advise…
gpsInfo.lat = myGPS.getLatitude();
gpsInfo.lat /= 10000000;
gpsInfo.lon = myGPS.getLongitude();
gpsInfo.lon /= 10000000;
Thank you.
Hi Donald,
Which example are you following? Are you using the [Get Position example or something else?](SparkFun_Ublox_Arduino_Library/examples/Example3_GetPosition/Example3_GetPosition.ino at master · sparkfun/SparkFun_Ublox_Arduino_Library · GitHub)
Yes, Get Position Sample. It gives me a string of numbers without a “period”. I need to divide it by 10000000 to be able to use it.
