uMax Package
I have a chip that I’d like to be able to use in my final design. It is an 8pin DC-DC converter in the uMax package. The chip is the MAX1675.
I’m concerned because the part layout for this chip in Eagle seems to violate the DRC. Upon manual inspection, it seems to be just a touch less clearance than 8mils between pins (around 7.87 mils). Is it possible to use this device with batchpcb’s manufacturing abilities or should I select an alternative? Maybe I could mess around with the package and make the pins a little bit narrower.
Let me know what you guys think.
Our DRC is set a bit lower than 8. If it passes our DRC, we can make it.
Cheers,
–David Carne
