Unable to see any services on BlueSMIRF
I applied +5 and Gnd to my BlueSMiRF and connected the CTS to RTS.
I’m using a Dell laptop with builtin bluetooth, and I’m running XP Pro with SP2 applied.
I can see the BlueRadios device, but Windows tells me there are no services available.
If I try to Quick Connect using Bluetooth Serial Port, then I get the error, Service Bluetooth Serial Port is not found on device BlueRadios.
If I try to connect using my Dell Axim v50, then I can see the COM0 service.
Does anybody know how to setup Windows XP to connect to the BlueSMiRF?
I discovered that if I clicked on “Update Driver…” for the Bluetooth driver (replacing the WIDCOMM driver with the Microsoft one) then everything started to work fine.
Thanks for posting what you found Dave!
-Nathan
Yes - thanks, Dave, your post helped me.
