Hello guys,
I got a 6DOF v4 the other to use for my Master thesis. And after taking the first hurdle of realizing that the batteries needed a charge up it worked fine for some time ![]()
Now I run into the following problem. I believe itâs easier to use the module in binary mode with Matlab (easier to handle the readings), but when I switch to binary mode sooner or later the connection drops and then the module canât be used for some time.
I can still establish a connection (the red diode lightens up), but even Hypterterminal doesnât get any response from it. No menu, no readings, nothing. Usually when I leave it for some time (unplugged from the power supply) it works again at some point (but that canât be how itâs supposed to be)
When the connection drops, the sampling stops as well (if I remember well) and sooner or later the status LEDs start to blink in the form of âall onâ, âall offâ, âall onâ. A mode, which is not talked about in the manual
Any suggestions on this? What I basically want is to have it work reliably in binary mode, 'cause then I wouldnât have to bother with the String handling and half lines due to overwritten buffer etc.
(It is quite a pain in the ass to use with Matlab anyway, but I can live with that)
Thanks a lot for your comments,
Sandro
