Dear spartkfun team,
I have these two modules:
Base: https://www.sparkfun.com/products/17369
Rover: https://www.sparkfun.com/products/16481
I have followed this tutorial to configure them: https://learn.sparkfun.com/tutorials/se … rtk-system
In the picture I show you a provisional setup where I get RTK Fixed but it varies a lot and very fast between RTK Fixed, RTK Float, DGNSS and sometimes it goes back to 3D. It does not stay constant in RTK Fixed.
The next setup I did was to change the rover antenna and put it on a tripod to put it higher. I get the same results.
The signal is good.
Why does it vary so much, is it normal?
Any solution to get more stable RTK Fixed?
Thank you for your help.
