I am trying to upload the test file on Sparkfun’s website to a microSD card. I am using an ArduinoUNO and the Sparkfun SD shield. The code compiles fine on my computer but the test file will not show up on the microSD card when I try to access it. I saved the SDfat library in Documents>Arduino>libraries>SdFat. I am not sure if there is an error in where the library is being saved or where my test code is being saved. Right now I have it saved in the libraries folder but have tried a few other places as well. Thanks for the help.
The code I am using from the Sparkfun website is below:
//Add the SdFat Libraries
#include <SdFat.h>
#include <SdFatUtil.h>
#include <ctype.h>
//Create the variables to be used by SdFat Library
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
char name = “Test.txt”; //Create an array that contains the name of our file.
char contents[256]; //This will be a data buffer for writing contents to the file.
char in_char=0;
int index=0; //Index will keep track of our position within the contents buffer.
void setup(void)
Serial.begin(9600); //Start a serial connection.
pinMode(10, OUTPUT); //Pin 10 must be set as an output for the SD communication to work.
card.init(); //Initialize the SD card and configure the I/O pins.
volume.init(card); //Initialize a volume on the SD card.
root.openRoot(volume); //Open the root directory in the volume.
void loop(void){
file.open(root, name, O_CREAT | O_APPEND | O_WRITE); //Open or create the file ‘name’ in ‘root’ for writing to the end of the file.
sprintf(contents, "Millis: %d ", millis()); //Copy the letters 'Millis: ’ followed by the integer value of the millis() function into the ‘contents’ array.
file.print(contents); //Write the ‘contents’ array to the end of the file.
file.close(); //Close the file.
file.open(root, name, O_READ); //Open the file in read mode.
in_char=file.read(); //Get the first byte in the file.
//Keep reading characters from the file until we get an error or reach the end of the file. (This will output the entire contents of the file).
while(in_char >=0){ //If the value of the character is less than 0 we’ve reached the end of the file.
Serial.print(in_char); //Print the current character
in_char=file.read(); //Get the next character
delay(1000); //Wait 1 second before repeating the process.
