how about a breakout board using the SL811HS?
http://www.cypress.com/portal/server.pt … pn=SL811HS
this chip is easy to implement, has a 8-bit data bus which would make it easy to use with some smaller products.
the board would also provide a 5V 500mA power source for the usb host. maybe something like the TI TPS61027.
http://focus.ti.com/docs/prod/folders/p … 61027.html
this way you could provide a single 3.3v power source for both the host controller and the usb interface.
