Use extended analog in on Redboard Turbo card
Hi
Does anyone know what code, and where to change it, to be able to use AIN16 on D4 pin and AIN17 on D3 pin?
Hi, thanks for posting.
I personally have not tried to accomplish this. Below is a forum thread that appears to go over adding additional analog pins to a SAMD21 device in Arduino:
https://forum.arduino.cc/t/arduino-zero … uts/350356
I hope this helps.
Hi TS-John
Thanks for the reply. I actually did see this post. But since it was quite old I assumed there might be an easier way to accomplish. I have a need for 12 analog pins in and 4 PWM out for servos controlled by footswitches. Will try to program the codes according to the post. if it works i can post the codes here for other to copy.
