Use of NTRIP via SW MAPS for RTK FACET
SW MAPS does not include NTRIP in its configuration options when I select RTK FACET as my Bluetooth GNSSS Connection device.
The SparkFun RTK Facet Hookup Guide suggests that the NTRIP option is only available when using a device named SparkFun RTK Surveyor or u-blox RTK.
What should I do in order to use NTRIP with my RTK FACET?
https://cdn.sparkfun.com/r/600-600/asse … SWMaps.jpg
Before connecting to an RTK device over Bluetooth within SWMaps, be sure to click on the ‘Instrument Model’ arrow and select SparkFun RTK Surveyor for all RTK products. After which, you’ll see NTRIP available as shown in the hookup guide: https://learn.sparkfun.com/tutorials/sp … -and-ntrip
Ah. Yes. That solved the problem. Thanks.
Glad to hear it!
