I would like to use 2 Single QWIIC relays. I have changed the address of one of the relays. The change works great. My question - How do I code to change the states of each relay? I’m not sure what code to write to make each relay turn on. I really don’t want to use a quad relay because 2 of the relays will go unused. Thanks.
There’s some example code in the [hookup guide, it’s pretty simple to do with our library.
To turn the relay on send:
relay.turnRelayOn();
To turn the relay off send:
relay.turnRelayOff();
You will need to modify the code a bit for 2 relays, but start with just getting one running first.](https://learn.sparkfun.com/tutorials/qwiic-single-relay-hookup-guide)
Sure. I understand how to turn one on. My question. - How do I distinguish the two relays when trying to turn each one on?
You have to assign one relay to one I2C address and the second to another.
Qwiic_Relay relay1(0x18);
Qwiic_Relay relay2(0x19):
Once you’ve done that, one relay becomes ‘relay1’ and the other becomes ‘relay2’.
// Let's turn on relay1...
relay1.turnRelayOn();
delay(500);
// Let's turn that relay off...
relay1.turnRelayOff();
delay(500);
// Let's turn on the relay...
relay2.turnRelayOn();
delay(500);
relay2.turnRelayOff();
delay(500);
Awesome! Thank you so much.
C Henderson
