Using OLA with LoRa
I’m using Open Log Artemis with external BLE module to stream low frequency sensor data to a RPi gateway. It would be nice to have greater range than BLE provides, so LoRa seems worth investigating.
Can anyone suggest hardware which would allow an OLA (via the RX/TX pins) to communicate with a RPi over LoRa or other longer range low power protocol.
2 of these https://www.sparkfun.com/products/18074 or 2 of these https://www.sparkfun.com/products/18215 should handle what you’re after :smiley:
