I need to send sensor data from SparkFun Pro RF - LoRa, 915MHz (WRL-15836) to Serial Telemetry Radio Kit - 915MHz, 100mW (WRL-15007). Is it possible to send data in such a configuration?
I really appreciate any help you can provide.
Nilanjan
Unfortunately the telemetry receiver is not compatible with LoRa so the two devices are not able to communicate with one another.
As long as you’re using the telemetry kit, you could attach one transceiver to an Arduino along with your sensors and use the other transceiver to receive the data though.
