Hello, my project requires using Raspberry Pi Zero to analyze sensed data and Sparkfun Triad Spectroscopy Sensor (AS7265x) has what I want. However, since the Triad Sensor doesn’t have a comprehensive library for python-based processors, I decided to employ the ‘sparkfun-qwiic-i2c’ library from pypi.
The challenge here is that the library doesn’t have a sample usage code and so I am finding it very difficult to implement. For instance I don’t understand what is meant by the parameter, ‘commandCode’ in the library; and some other issues.
I therefore humbly request for a sample usage code to enable me implement the library, and I will be very grateful you did.
Thank you.
