Using the Sparkfun library in Fritzing
I have a copy of the sparkfun library in Fritzing but when I try to use the sparkfun tb 6612 fng item in the ‘other’ section of the sparkfun library the picture is just a white sheet and the three options in the lower box are all white sheets, if I click on it it says item not found and locks my computer so that apart from switching off and back on again I have to do a ctrl_alt_delete to get the task manager and close fritzing from there losing all my work.
Do I have a corrupt copy of that file or is there a problem with the download of the file?
Bob
I’m not sure about the ‘other’ directory, but there’s one in the ‘products’ directory that might work? https://github.com/sparkfun/Fritzing_Pa … n/products
