Hi everyone,
I’m trying to design a board around the TSSOP version of the TLC5940 IC (a 16-channel LED driver) present in SparkFun’s Eagle library. This chip has a thermal pad on the bottom which TI recommends connecting to a ground plane. Whoever designed the Eagle package was nice enough to include an SMD thermal land for soldering the thermal pad on the underside of the chip to, as seen here:
Based on my understanding of [this “PowerPAD Made Easy” guide (pdf) and [this technical report (pdf) from TI, I think I have a couple of options for making use of the powerpad:
Connect the powerpad to a large area of copper and expose an area of this copper using a solder-mask defined pad. (single-layer PCB)
Do #1 AND add thermal vias in the exposed copper region to connect to an internal ground plane. (multi-layer PCB)
So far, does this seem correct?
My real question is how do I actually go about connecting that SMD pad in the package to my ground plane in Eagle? When I place my chip on the bottom layer, which has the ground plane, I see a border around the thermal land:
Even if the chip were on the top layer, I don’t see how I could connect the thermal pad to the ground plane without using vias.
-vishal
(p.s. I have read phalanx’s replies on this thread: viewtopic.php?f=20&t=7314 . This was very helpful and probably the route I want to go, but I need to know how to connect up these pads/vias first.)](http://www.ti.com/lit/an/slma002g/slma002g.pdf)](http://www.ti.com/lit/an/slma004b/slma004b.pdf)
