Venus GPS header files and example code
Just got to integrating my Venus GPS breakout board to the microcontroller.
Does anyone have library, header files and basic command sets for this chip?
I am connecting through the TX/RX pins (TTL serial). I will eventually use 115200 baud and 10Hz update.
jpnovak:
I have c++ code for Visual C++ and an FTDI USB/Serial adapter if you’re interested.
Thank you for the offer. You have a PM.
Please can you also send the code to me?
Thank you in advance.
D
I know it’s an old thread, but…
I’m looking for the same header files and example code. Does anyone have it?
With an ftdi board and the GPS Viewer software, you can change the nvram settings as you’d like and they’ll remain set. (In case you can’t find the code to set it on your controller)
