VL53L1X freezes
occasionally my VL53L1X freezes at a certain distance, eg 1234 when using the sample code below.
while True:
    try:
        ToF.start_ranging()
        time.sleep(.01)
        distance = ToF.get_distance()
        time.sleep(.015)
        ToF.stop_ranging()
Is there anything I could check? So far only booting the device helps.
Maybe the two different ‘sleep’ amounts are causing a clock timing error? Try changing those to the same value (either 0.1 or 0.15?)
Does it un-freeze intermittently as well?
