I’m working with a [ToF Range Finder Breakout - VL6180 but I’m not getting the desired results.
I’ve tested with an Arduino Uno (by following [this guide) as well as a Raspberry Pi 4 (by following this guide [this guide), with their respective libraries.
I couldn’t read any values on the Arduino, neither on the SDA and SCL pins nor on the A4 and A5 pins.
On the Raspberry Pi 4, I was able to read the illuminance values (lux) but not the distance values (as seen in the image below).
In fact I’m getting the error 11, which, if I’m not mistaken, according to the Table 1 from Page 2 from [this document, it says the sensor need to be reset.
How do I reset the board?
and
What could I have missed from this to not be working on the Arduino?
Thanks in advance,
Luke](https://www.st.com/resource/en/design_tip/dm00114111-vl6180x-range-status-error-codes-explanation-stmicroelectronics.pdf)](https://imgbb.com/)](Python & CircuitPython | Adafruit VL6180X Time of Flight Micro-LIDAR Distance Sensor Breakout | Adafruit Learning System)](VL6180 Hookup Guide - SparkFun Learn)](SparkFun ToF Range Finder Breakout - VL6180 - SEN-12784 - SparkFun Electronics)
