Wake on Shake - Amps
Hi, how many amps can the Wake on Shake handle? It says the voltage but I can’t find amps.
Hello!
The MOSFET that controls the output is rated for 2A.
We’ve not tested the assembly at this current but as long as nothing on the board is getting hot, you’re probably OK with currents on the VOUT pin that are less than 2A.
