My name is Chanwoo Lee, and I am a student at KAIST in South Korea. I am setting up a system for miniscope imaging, sound stimulation, and active avoidance experiments.
I am using the SparkFun WAV Trigger to play WAV files from a microSD card using external 5V TTL signals.
However, I am having a problem with the external trigger inputs. At first, the sound plays correctly, but after some time, the playback becomes irregular and eventually stops responding to TTL signals.
I would appreciate your help.
1. Hardware and Settings
Board: SparkFun WAV Trigger (16 trigger inputs)
Power supply: 6V DC, 3A adapter
Audio files: 16-bit, 44.1 kHz, stereo WAV files
Trigger settings:
Hardware Interface: Active (3.3V/5V)
Type: Edge
Invert: ON
Function: Normal
TTL sources: Noldus USB-I/O Box (PTIO-0021) and Arduino Uno
Wiring: TTL output to T1 or T2, and GND connected between the devices
2. Tests and Results
Test 1: Noldus USB-I/O Box
When the Noldus I/O Box is not connected to the WAV Trigger, the TTL output works normally.
LOW: 0V
HIGH: about 4.7V (stable)
When I connect it to T1 on the WAV Trigger, the sound plays correctly at first. But after repeated triggers, some sounds are missed, and eventually playback stops.
When this happens, the TTL HIGH voltage drops to about 0.5V.
After disconnecting the WAV Trigger, the Noldus TTL voltage returns to normal.
Test 2: Arduino Uno
I also tested with an Arduino Uno to check whether the problem was caused by the Noldus I/O Box.
I used digital pin D2 to send the following signal:
HIGH (5V) for 1 second
LOW (0V) for 9 seconds
Repeat every 10 seconds
The Arduino output works normally when it is not connected to the WAV Trigger.
However, when connected to the WAV Trigger, I observed similar voltage drops and playback problems.
Test 3: T1 and T2
I tested both T1 and T2 inputs.
Both worked at first, but the playback became irregular over time and eventually stopped responding to external TTL signals.
Test 4: TEST Button
The onboard TEST button has always worked normally, even when the external TTL triggers stopped working.
Test 5: Restarting the Board
Sometimes, turning the WAV Trigger off and on did not solve the external trigger problem.
3. Questions
Could this be a problem with the WAV Trigger board or its external trigger inputs?
Has anyone experienced a similar problem where the TTL voltage drops after connecting the WAV Trigger?
Is there anything wrong with my settings or wiring?
What should I check next to find the cause of this problem?
I am still learning about electronic circuits, so I would really appreciate it if you could explain any troubleshooting steps in simple terms.
Thank you very much for your help!
Chanwoo Lee
KAIST, South Korea
